i was looking through and some information seems quite outdated
Example
The hard drive is where all the information on your computer is stored.
Our hard drives are branded either Maxtor, Seagate, Western Digital, Hitachi or Samsung. We cannot guarantee which brand of hard drive you will receive on your new computer, but as you can see, we only use leading brands.
To decide what size hard drive you will need, you need to consider that for example an 80GB hard drive is 81,920 megabytes. Confused? Data in volume is called bytes:
1,024 Byte = 1 Kilobyte (KB)
1,024 Kilobyte (KB) = 1 Megabyte (MB)
1,073,741,824 Bytes = 1 Gigabyte (GB)
1 Gigabyte (GB) = 1,024 Megabyte (MB)
To safely install Windows XP on your computer you need approximately 5 gigabytes of space. A massive computer game may take up 1 gigabyte of space, but usually games only take up a few hundred megabytes.
Most programs range from 5 to 500 megabytes, and therefore the average computer user will struggle to use up 80gigabytes of hard drive space. However, if you download movie clips, music and install lots of games, you may find you will need a 120gb or larger hard drive to cope with everything.
RPM RPM (Revolutions Per Minute) is the speed that your hard drive rotates. The more revolutions per minute a hard drive rotates, the more data it can copy/move within the given period of time. A 7200rpm hard drive can copy/move data faster than a 5400rpm hard drive.
See also:
Example
See also:
