Looking for the best build for my budget
doates
Alright lads ill stick to your build with the 2 m.2 i might as well. one last question i have had compatibility issues with corsair ram with ryzen 3000 series cpu not working at the advertised mhz. Do pc specialist turn on docp and adjust the mhz of the ram to get the most out of it?
PCS will set the RAM to which ever one you purchase, you shouldn't have to do anything on your end
doates
Alright cheers man. just i bought a pc previously pre build with 3000mhz ram and its running at 2133 and i cant seem to get it to go up anything. but i did some research and it looks like its an issue with the r5 1600 and certain corsair ram. As long as they dont let it default to 2133 which would be a big bottleneck with this system.
doates
PCSPECIALIST.IE SPECIFICATION
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
NOT REQUIRED
Price: €2,299.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/SUBzrm0PU5/
NOT REQUIRED
Great well balanced system for 1440p with headroom for future gpu upgrade ! Its nice :)
Any last advice before i place my order?
Also dotes after you have placed your order before it goes into the building stage you can amend your order incase you change your mind on anything.
when placing your order itll advise you that you can save money going for a lower power supply if you want the headroom in future to upgrade stay with the 850w rmx
doates
I dont think i will upgrade i think once the time comes ill just build a new pc. A 750w rmx would do the job right?
doates
I was told upgrading the ram to 3600 would help the ryzen a bit. but it looks to be overclocked at anything above 3200. Is there anywhere i can leave a note for the PCS to make sure that my rams running at its best freq?
As already advised it will run at whatever frequency you order.
doates
i tried order this pc but they are out of stock of CoolerMaster MasterLiquid Lite 240 High Performance Liquid Cooler. Whats the best alternative
H115i Elite Capellix. You could go for the H100 but with the price difference it's not worth it.
If it comes into stock while you are waiting on it building you can always switch it back. The H115i is a different beast though and will cover any CPU you should upgrade to in the future.
