More cooling selections?
AG Systems
I was wondering if you are going to add more selections in CPU cooling?
It would be nice to have a better selection of fan coolers for overclocking because the Titan Fenrir doesn't fit on the new P67 motherboards, and some people may not want to use water cooling. Just a thought.
Maestro
Guest
Titan are producing a new bracket which will allow the fenrir to fit on the asus p67 motherboards. Should be with us in a couple of weeks.
adacaw
It's on the list but I keep getting this message when trying to proceed.....
Checking your specification... [Your specification failed our initial checks.]
We've checked your specification for compatibility. Please see our suggestions below:
1. Unfortunately the Titan Fenrir CPU cooler does not fit your chosen motherboard. Please change your choice of CPU cooler or alternatively select a different motherboard.
That's with the ASUS® P8P67 motherboard selected for the system?
PCS
Administrator
Staff member
The Fenrir does not fit some Sandy Bridge motherboards. There will be a solution available, but it's likely to be 1 - 2 months away yet.
