Hello people,
Need your advice/suggestion please.
I recently got my PC from PCSpecialist (spec below), and since I received it I have had some issues with it. One of the issues is that the graphics card, as specified in the spec below, did not come as described on PCSpecialist website. On the website/and from the spec below, the graphic card is meant to have HDMI and DVI, however, it arrived with just HMDI and VGA. Following a few emails and letter to PCSpecialist, PCSpecialist requested I returned the PC, and installed another graphics card with HDMI and DVI - a NVIDIA GeForce 210. Whether this is a better graphics card than my original graphics card - an integrated Intel HD graphics, I do not know! Anyway, what's occurred since the new graphics card was installed is that when I put my PC to sleep, and then come back to restart the PC (by pressing any key, or even pressing the power button once as suggested by Tech Support when I phoned to report the issue), the PC restarts, but the monitor does nothing and just remains blank. I have to then resort to powering off the PC completely and restarting it. This did not use to be the case before the new graphics card was installed, i.e. I put PC to sleep, come back to restart, no problem, PC and monitor restarts. When I phoned PCSpecialist Tech Support, I was told some graphics card do not like the PC being put to sleep, and basically I just have to live with the new graphics card and not ever putting my PC to sleep, and that the 'sleep mode' is really for laptops and not PC.
This just does not seem right to me. Why the sleep mode function on PC then! I like to put my PC to sleep when I want a short break, and do not particularly want to switch my PC off completely, to save on energy (good for the environment), and also to give the fan that you can hear continuously fanning and humming away (which is quite loud) a break. Do you guys agree with the response I got from Tech Support, or should I demand a solution to this? I would really like to be able to put my PC to sleep from time, and don't want it to run continuously all day without a temporary break, when I am away briefly from the PC doing something else.
Thanks
Dan
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
Intel® Core™i5-2500k Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8H67-M: M-ATX, DDR3, USB 2.0, SATA 6.0Gb/s, CrossFireX™
8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
INTEGRATED INTEL HD GRAPHICS (HDMI, DVI, 1920 X 1200)
Memory - 1st Hard Disk
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
350W Dual Rail PSU + 120mm Case Fan
INTEL SOCKET LGA1155 STANDARD CPU COOLER
Network Facilities
NO OFFICE SOFTWARE
Miscellaneous
FREE Battlefield 3 with 2nd Generation Intel® Core™ Processor-K
Quantity
1
Price: £566.10 including VAT and delivery.
Thanks
Dan
Network Facilities
NO OFFICE SOFTWARE
Miscellaneous
Quantity
1
