Pc specialist Cable Management Question
aman7860
I have ordered a gaming pc with a haf 922 case. A lot of people say how it has amazing cable management and good air flow but if i wanted a really tidy pc interior, do they sleeve your cables or does the pc look a mess on the inside ?
MrShteeeve
Here's a few examples of Teaz's recent delivery :), you may be able to request cable sleeves at a slight extra cost possibly, you'll have to give them a ring on 0844 499 4000 or email them asking. Hope this helps somewhat.
Steve
Edit:
The first image is off the underside of the Mobo, the side where the most of the airflow is achieved is the 2nd picture :)
aman7860
Steve
Edit:
so in the second image, those are default from pc specialist ?
MrShteeeve
Lmao, sorry about that, thought you were still talking about the PC in the pics, my bad! Mine set me back a little under a grand which I thought was a very good price :). It performs really well I'm impressed with it.
vanthus
Member Resting in Peace
If my max power usage is 401 with 20% increase. Will cold cathodes and new fans increase it that much?
In reply to your other thread "cold cathode voltage"I said said it depends on how many & what size.
The lights have a low power consumption,you can get 12"(inch) kits including the inverter,which run at about 4 watts,a fan say about 3watts?
Teaz
Godlike
LoL i'll have to contradict you a bit there steve as the second image was not default cable management by pcs, that is my own doing as most of cables when first received was lodged in my hdd bay and wiring was more erratic :) i just didnt grab a picture from the front as it instantly RMA-ed lol
MrShteeeve
:( It wasn't far off though, the wires weren't hanging all over the shop blocking airflow were they? It was all shoved in one place out of the area of major airflow, albeit not very aesthetically pleasing but still not restricting massive amounts of airflow? :( lol.
Teaz
Godlike
actually it did, it clogged some airflow which made the case temps pretty warm when i was testing it with my thermometer, it blocked out 4.5c. it was blocking the front fan.
Gorman
What the end result looks like is entirely dependant on the case and the hardware in it.
All machines are cabled with an eye on airflow, although time constraints means that its never going to be as imaculate as one that an enthusiast has spent 4-5 hours lovingly cabling.
