Hi
I'm on the brink of shelling out around £1k on a new PC base unit, as mine is 7 years old and dying fast.
I've put together a spec that I think is pretty well suited to my needs - photo and video editing primarily - and that will stand the test of time and last another 7 years.
I'd be grateful for any comments on the spec below, and also on cases. I've put the Storm Sniper case in the spec, but that's more on looks and the front connectors being at the top rather than necessarily being the best. Would one of the cheaper choices be as good?
COOLERMASTER CM STORM SNIPER - NEXT GEN GAMING CASE (£129)
Intel® Core™i7-870 Quad Core (2.93GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55D-E: USB 3.0, SATA 6.0GB/s, CrossFireX™ SUPPORT
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 2GB KIT)
1GB ATI RADEON™ HD 5770 PCI EXPRESS - DirectX® 11
1st Hard Disk 1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
Sound Blaster® Audigy™ SE (£25)
Modem NONE, I WILL BE USING BROADBAND
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£108)
Warranty 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
I'll point out that I plan to add either a second 1TB HDD (Samsung Spinpoint F3) or possibly a Kingston 64GB SSD boot drive instead, after delivery as well as a dual TV tuner (as it's cheaper than getting it done by PC Specialist on build).
Thoughts appreciated.
Thanks
Peter
Thanks
Peter
