Okay so im going to be buying this rig for the release of FFXIV and im sure most of you have heared about the diabolical recommend specs. There is no way i can afford something they are asking my budget is £750-£800.
So i am pretty well decided to go with the AMD Phenom x4 965BE for a cpu wherever i look it seems to get good reviews and seems to me like a good cpu... So the rest was down to the GPU really, i was pretty stuck with going tfor the HD 5770 which from reviews etc i htought looked like it could cope with medium level graphics for FFXIV... But i did a bit more research tonight and have found the 460GTX 1Gb... I seems to outperform the 5770 everywhere and i have found a rig which would fit it for 780...
My main question is... Will the change in motherboard have any mojor drawbacks? I am aware an will not be able to crossfire in the future as i had planned for dual 5770's and is the 460GTX better than 5770? The only differences in the systems are...
Motherboard - ASUS M4A79XTD EVO: DUAL DDR3
Graphics Card - 1GB RADEON HD 5770 GDDR5
Compared to....
Motherboard - ASUS M4A87TD/USB3: DUAL DDR3 USB 3.0
Graphics Card - 1GB NVIDIA GEFORCE GTX460 GDDR5
Any benchmarks from FFXIV with similar rigs would be helpfull
Compared to....
