RECOIL 15 MISSING CPU and GPU Power Limits and NVIDIA Whisper Mode.
Akli
My laptop is acting up again. Did a clean install of win10. let it install all drivers. Lastly installed ControlCenter 3.1.35.0. My laptop cpu runs at 0.40ghz. And I am missing features in the control center.
Can you guys please help me? Ever since I got this laptop it has been a really bad experience. Send it back 3 times. Was told the problems were fixed. But I keep running into issues like this. I think I am just gonna return it and buy a laptop thats more relaiable.
The reason I did a clean instal of win10. was because I kept getting bsod after updating to win11. But even after reverting with a clean install. I get the BSOD.
Chassis en display
Recoil-serie: 15,6" mat QHD 165 Hz sRGB 100 % led-breedbeeldscherm (2560x1440)
AMD Ryzen™ 9 8 Core 5900HX (3,3 GHz, 4,6 GHz Turbo)
Geheugen (RAM)
8 GB Corsair 2400 MHz SODIMM DDR4 (2 x 4 GB)
Grafische kaart
NVIDIA® GeForce® RTX 3070 - 8,0 GB GDDR6 Video RAM - DirectX® 12.1
1e M.2 SSD-station
2 TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (maximaal 3500 MB/R, 3300 MB/W)
Geheugenkaartlezer
Geïntegreerde SD-geheugenkaartlezer
Wisselstroomadapter
1x 230W-oplader
Stroomkabel
1 x stroomkabel van 1 meter voor Europa
Batterij
Recoil Series geïntegreerde 94WH lithiumionbatterij
Warmtegeleidende pasta
ARCTIC MX-4 VERBINDING MET EXTREME THERMISCHE GELEIDBAARHEID
Geluidskaart
2-kanaals High Definition Audio + MIC/headsetaansluiting
Draadloze netwerkkaart
GIGABIT LAN & DRAADLOOS INTEL® Wi-Fi 6E AX210 (2,4 Gbps) + BT 5.0
USB/Thunderbolt-opties
1 x USB 3.2-POORT (Type C) + 3 x USB 3.2-POORTEN
Taal toetsenbord
MECHANISCH RGB-TOETSENBORD MET ACHTERGRONDVERLICHTING PER TOETS VOOR DE VS
Besturingssysteem
GEEN BESTURINGSSYSTEEM VEREIST
Taal van besturingssysteem
Nederland/Nederland - Nederlands
Windows-herstelmedia
GEEN HERSTELMEDIA NODIG
Office-software
GRATIS 30 dagen Microsoft 365® op proef (besturingssysteem vereist)
Antivirus
GEEN ANTI-VIRUSSOFTWARE
Toetsenbord en muis
GEÏNTEGREERDE TOUCHPAD-MUIS MET 2 KNOPPEN
Webcam
GEÏNTEGREERDE HD-WEBCAM 1MP
Garantie
3 jaar gouden garantie (2 jaar ophalen en retourneren, 2 jaar onderdelen, 3 jaar arbeid)
Bezorging
2 DAGEN VERZENDING NAAR NEDERLAND
Bouwtijd
Standaardversie - ongeveer 6 tot 8 werkdagen
Aanbiedingsitem
Ontvang een Founders lidmaatschap van 6 maanden van GeForce Now bij een bepaalde selectie van RTX 30 laptops
Welkomstboek
PCSpecialist Welkomstboek - Nederland
How did you install windows? What method? How did you configure drivers?
Can you post a screenshot of your Windows update page and device manager?
Where are you sourcing control center from?
Akli
Installed windows11 through windows 10. Then I got the BSOD stuff. then I went back to win10 using a media creation tool from the MS website. not only did I still have the BSOD. but control center was acting up and my cpu runs at 0.40ghz regardless of mode.
Control center is from my download page under win10.
Yes installed all my drivers and there are no problems showing in the Device Manager.
Windows I have tried to reinstall windows twice once with 11 and when that gave me trouble I went back to 10.
I used the correct installers. Let windows update fully and then manually installed the drivers windows could not find. (Which was only the Radeon graphics)
I have decided to refund the laptop.
I cannot imagine this happening down the road when my warranty is expired.
I have already sent this laptop back 3 times for a: Non-functional lightbar, screen clouding, broken CPU clock speed. The latter does not seem to be fixed. Purchased this laptop in august. have been struggling with this since. Lots of inconveniences, not being able to work from home, getting behind schedule for my work. Never really had the opportunity to really enjoy the specs. And now it is already outdated.
Where did you source your drivers?
I don't think there's anything wrong here, just sounds like windows isn't configured.
The reason it was BSODding in Windows 11 is because you'd need an updated Control Center which you'd have to ask PCS about.
I don't think there's any issue here, and you're well outside the return windows as far as I'm aware.
Akli
Well yes and no sure it has been a while but most of that time has been waiting for RMA's having to wait a month or 2 to get it back.
barlew
Godlike
I am pretty sure that TongFang control canter is currently not compatible with Windows 11 which would explain the problem. Cant remember where I read that though.
Akli
I did update it to the win11 version which is 3.1.39.0 after going to win11. And that is when the problems started happening.
But now I cannot get it to work in win10 with version 3.1.35.0. And the painful part is without control center my cpu runs at 0.40ghz.
So setting up a fresh instal takes ages. only to have it not work again.
barlew
Godlike
Where did you get that install from and what makes you think it is Win 11 compatible? Did you get it from PCS?
I let windows update, and then I looked in device manager what was missing. and then I downloaded that from the pcs download page
That's not how you configure windows, from the BSOD code and what you're describing there's nothing wrong here, you just haven't configured windows correctly.
Where did you source this?
Akli
There might be nothing wrong here but I don't want to deal with a user experience this bad. Because I cannot get it to work.
I already tried 2 times.
It's not PCS issue that you're not familiar with Windows, you need to know how to manage and configure windows to run a custom pc or laptop.
I don't think you'll be eligible for a return.
Akli
Any suggestions then? Teach how to get my clockspeeds back to normal so I can configure windows more quickly and correct. Because this all happened after updating and I don't know how to fix it. I already send the laptop back for it once and they told me it was fixed but the problem came back. So if they cannot fix it How am I supposed to fix it?
The cpu should work fine even with ControlCenter not installed right?
barlew
Godlike
You need to reinstall Windows 10 from a USB. When you do this you need to make sure you delete all partitions from the drive you are installing too so that it is a clean install.
Then you need to run Windows update continuously until all updates are installed. Including optional updates.
At this stage I would suggest pausing and taking a screen shot of your device manager, expanded so we can see any drivers that have been missed and also a screen shot of your Windows Update screen.
Once that is confirmed all good we can advise on any further drivers that need to be installed and then finally install the correct version of Control Center.
Akli
Thank you I will try now with windows 10. And keep you guys updated.
Akli
Ok new fresh instal of windows.
Letting windows update
After that was done it is still updating stuck at 20%
In device manager it only gives me an error for these 2 drivers
cpu is still slow even after letting it update for a while.
This is what is bothering me the most. and they told me they fixed it after I send it back for RMA. But the problem is still there.
Before I upgraded to Windows 11 it was not like this. I think this might even be an issue in the bois no? Doesn't the bios control
Based on the device manager image, I think I need to install the WLAN driver and AMD Radeon Driver.
which is exactly what I did the previous time. Can someone correct me before I am going to have the same problem?
