Uk websiteDid you order it from the UK site or the dutch site?
So you haven't been charged any VAT.Uk website
It's the SSDWhat is M.2 SSD Drive?
As already said, you'd configured a SATA SSD which aren't used any more, they're old and about 7 times slower while being around the same cost.Why did u add that and remove Storage Drive? Is it better?
Where those all the problems or are there more problems in my build?As already said, you'd configured a SATA SSD which aren't used any more, they're old and about 7 times slower while being around th i have another question. So if i want to keep 3060 ti what things do i have to upgrade? because
Ok, I'm not sure how to say this, you seem to be having problems understanding what a PC is.Where those all the problems or are there more problems in my build?
Well rip me. Thanks for all ur help thoOk, I'm not sure how to say this, you seem to be having problems understanding what a PC is.
You can't just build a pc out of any components you like. It's a system and it all has to balance to get the performance.
If you were to order the system you'd configured, it would perform awfully, because even though it's got a 3060ti, the rest of the build can't support it, and so performance would suffer.
At your budget, YOU CAN'T AFFORD A 3060ti or anywhere close to it.
The only way you can is by raising your budget to nearer 1800 Euros.
