What you mean non committal............. šAnyone else think that's got hints of a Boris Johnson speech?
Thanks for setting me straight @Scott. I needed that! š¬3080 is bordering on ridiculous now. You can't really future proof the GPU as the technology changes so fast.
If you had the 3060Ti selected your order will be in with the distributor so as long as there aren't too many RMAs for the card then you will be fine for your spot.
Take the money saved, keep it in the bank and get them a nice upgrade next year with the latest gen GPU or etc
Just re-visiting your spec and checking some parts out. There are some significant upgrades you could make to future proof the system.
Change the CPU to a 5800X, especially with FS2020 in mind as the 8 cores will come into play pretty soon
With the change of the above the X570 Wifi Motherboard is worthwhile
Upgrade to the H115i. It'll help with the temps and do very well with the 5800X
Upgrade to the 1000w RMx, as above with the RAM..... you're going to end up with a monster build in a year or 2.... I can sense it. You will want a bit more juice for the high end GPUs.
Upgrade to 32GB of RAM, I know we all said 16GB but given where you are at now and with me reflecting where the PC will no doubt go in the future it's worthwhile.
Build is below, I couldn't select the 3060Ti so you need to add Ā£100 or so.
Priority wise, the list above from the top down is probably most important to least important.
ASUSĀ® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
512GB INTELĀ® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
1TB INTELĀ® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW)
CORSAIR 1000W RMx SERIESā¢ MODULAR 80 PLUSĀ® GOLD, ULTRA QUIET
LED Lighting
2x 50cm ARGB LED Strip
NOT REQUIRED
FREE 30 Day Trial of Microsoft 365Ā® (Operating System Required)
Google Chromeā¢
Standard Build - Approximately 13 to 16 working days
Price: Ā£1,873.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/SbV6Ad7Rru/
Yes, itād be absolutely fine šThanks @Scott . Happy with all your suggestions apart from the case - COOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE.
Mainly because I don't like the look!
Would my current selection, CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE not suffice taking on board the upgraded cooling?
Thank you @Scott. Couldn't have done it without all your help. I definitely ended up spending way more than I planned but at least I'm getting a system that I'm happy with and not some off-the-shelf PC.I'm genuinely jealous of that build
Oh dear you didn't get a bout of ABS (Amendment Button Syndrome) did you, that can be a terrible afflictionRight.....amendments made and submitted.
Also, I am starting a petition for PCS to not allow ANY changes to the original order once it has been submitted! š¤Ŗ
NOT REQUIRED
2nd M.2 SSD Drive
I'm also about to get a bout of domestic battery once the wife finds out out how much I've spent! And that's before the Ā£300 on a G5 monitor. š¬Oh dear you didn't get a bout of ABS (Amendment Button Syndrome) did you, that can be a terrible affliction
I'm "lucky" I don't have one of those to worry about, I just tell my 3 "grown up" daughters that I'm enjoying spending their inheritance & they can argue over the cycling & tech stuff when I'm gone.I'm also about to get a bout of domestic battery once the wife finds out out how much I've spent! And that's before the Ā£300 on a G5 monitor. š¬
