Just on this forum ive heard at least five cases of them bursting
Quite yeh, im fine with the titan anyway. As long as it keeps it cool im fine, and by the sounds of it, these days, CPUs are not the parts creating excess heat, that is the graphics cards job these days as they dont really have dedicated cooling, just 2 small fans built in
I dont have a clue how many they sell, and what the actual burst rate is, bim quite happy with the titan and that is that, i will not change to watercooling, one of the reasons being im also waaay over budget
i havent gone for a oc system the watercooling is purely out of necessity due to the fact the titan will not fit in my case with a side fan covering my gpu.
Why are you getting WC if you're not overclocking? your CPU won't run hot, and the cheaper copper one is even too much if you don't overclock, I've been running stock coolers the past 10 years and never, ever have my CPU's gotten anywhere near hot, wouldn't even call them warm.
What do you do with your computer then? CPUs get hot easily if you are playing a game or using Photoshop for exampleWhy are you getting WC if you're not overclocking? your CPU won't run hot, and the cheaper copper one is even too much if you don't overclock, I've been running stock coolers the past 10 years and never, ever have my CPU's gotten anywhere near hot, wouldn't even call them warm.
My CPUs always run hot under intense work and multitasking, so if you are not overclocking at all get the triple copper if you cAn afford it
the silent copper cpu cooler just wont cut it with my use so the choice would be the titan but if you read my posts it wont fit in the phantom case with the side fan hence the wc system. hope that answers your questions.
I opted liquid cooling, my rig is not overclocked. I needed a side fan so couldn't go for the titan just incase i lost the side fan on the sniper.
I can't offer an opinion about the titan due to the fact i don't have one. But eco is class!
woohoo someone in my boat thanks tom i have my 230mm nzxt fan on order so im hoping that and my new keyboard get here intime to fit on my pc striaght away so i can post pics on here
