UndeadJack
Master Poster
Downer i it doesn't fitg
Just rang up PCS to check what fan slots are not filled so i could order some and from what the tech guy said they have fitted the max ammount of fans, woohoo. but then went on to say apart from the one i wanted too cover my gpu as even the eco may be to large to fit the 200mm+ fan Il have to take a look when it comes and see what my options are since there are many slim 200 fans out there which may fit. next week and its here :rockon:
Isn't the radiator for the ECO II twice the length?So you are saying pcs said, they have removed the side fan due to the eco? sounds strange it fits on mine fine, erm unless the "ECO II" is bigger???
I'd call back up, and ask them to send you the 200mm side fan out anyway, even if they say it doesn't fit.
Did you speck to the sales guys or the tech guys?
yer bit of a bugger i spoke to one of the tech guys he said that they doubt it will fit but the fan will be sent along anyway but tbh i couldnt understand that much of what he said, the tech guy sounded very stoned and was mumbling alot....
not sure about the rad on the eco i thought it was a 140mm square but i maybe wrong il just have to wait and see, only the weekend to go and il be camping at the frount door with my laptop tracking my order.
i aint so camper im a assult sniper most of the time on bc2 agressive sniping ftw.
If your thinking about a evga sr2 board now i would suggest saving up alot, possibly falling off a ladder in work or selling a kidney.
Teaz did you get the name thing as a aticker from somewhere ormdid you draw it? I found a site a whioe back but cant remember now
Do you get a phenom sticker if you get a phenom computer?
Does the Sniper come with those usb 3.0 on Teaz's pc?
