mohnad
It's not installed then, need to reinstall.
Dear sir,
So I installed again and restarted the laptop, but still both folders are empty.
But I captured screen when it was installing, here it is
Kind regards
So my Sound Blaster is different to yours I had the dedicated sound card and an installation disc in my pcspecialist welcome pack
but have a look in
C:\Program Files (x86)\Creative as this is where all my options and exe files are perhaps yours might be there also.
but have a look in
That just won't show any errors if it experiences any.Dear spydertracks,
Did you noticed from the screenshot? it is showing ''/silent'' ? May be for that reason it is not installing ?
It needs to be off otherwise it will block installation.Dear sir,
Ya, it was "off". But I turned on and then I installed again. But still no files in creative folder.
Dear sir, so shall I download it from Clevo website ??It needs to be off otherwise it will block installation.
you need to be installing from the latest package on clevo, the CD one will be outdated.
That’s where you source any drivers.Dear sir, so shall I download it from Clevo website ??
Kind regards
I don't think you're downloadint he correct installer, I think that's an update rather than a full installation file? Are you sure that's the latest one also? Seems very old.Dear sir,
I downloaded from clevo website. and my laptop number is P775TMI
Is it correct selection ?
And when I am trying to run ''creativeaudioeffectscomponent, it run successfully and I installed it, but when I am trying to run ''SPKEQ_CLV_PCAPP_US_1_01_62. it's not running. I kept controlled folder access as ''off'' only. how to make it run ? I also turned off internet protection, firewall off, but still it's not running.
You don’t need to concern yourself with the installation directory.Dear Spydertracks,
Finally I got SBX driver setup files from PCS ''technical support'' for creative Sound and I installed it successfully. Can you help me in setting up the sound please. And what is this OpenAL folder in creative ?
Kind regards
That’s fantastic! So was it the software not being able to utilise all the cores properly?Dear Forum specialists,
@SpyderTracks @Scott @ubuysa
I am happy to inform you that the laptop is performing it's best. I have sorted out the issue with software vendor, and today I performed simulation and I used parallel solvers coupled and it solved it in no time, CPU went upto 100 % at some points and solved it in just 56 minutes which usually takes around 20 to 24 hours or sometimes more . Please find the attachments, you can see my simulation software in background. The only issue I saw is that the CPU temperatures are going upto 100 degree C. Is it throttling ?But I agree that for 56 minutes the CPU was on full roaring, so it definitely heat up 😉, Do I need to buy an external cooling fan stand for it ?
Kind regards
Cooling pad won't work until thermals are under control.Dear spydertracks,
Yes, Probably I think the problem was with the software. But resetting the BIOS also helped it because the first PCS guy who did changes in power management had messed the settings, the second PCS expert reset the BIOS which helped CPU to get back to it's normal position.
Regarding the undervolt, If you remember we have already tried undervolting, but it's not going below -0.05 V which is already kept default since the delivery. I am thinking of buying a cooling pad, what would you say ?
Kind regards
