barlew
The new Ionico has a slightly different model number to the Vyper but that's to be expected as its designed for the new GPU's. Whether it has the same issues as the Vyper I couldn't say however I am betting it does.Hi guys!
so they did remove the Vyper 17,3" from their website, but they have just released a new model called "17,3" IONICO", which seems to use the same Tongfang body.
For me as an architect it would have been a better option (i bought the Vyper 3 months ago) as it offers a QHD 100% sRGB display...too late I guess. It also offers the new RTX3060/3070 (Max-Q or not?) while keeping the same i7-10875H.
https://www.pcspecialist.co.uk/notebooks/ionico-17/
So are they still using the same Tongfang body despite the performance problems? i've tried to test mine while using it on battery, but haven't noticed any drop of performance...but it was just watching a movie or youtube. How should I correctly test it?
Many thanks!
Testing your laptops performance depends whether you bought the pre "fix" or not. If you bought it before the fix was released on here you would notice it straight away when running on battery.
If you bought it post "fix" then it may well be less pronounced. So for example, for me as I have installed the fix the problems don't kick in until the battery runs down to approx the last third. The performance of the laptop then tanks.
